Front leveling a 2WD 4th gen Crew Cab
Old Jul 5, 2013 | 01:40 PM
kx250frider617's Avatar
kx250frider617
BTW, the lift spindles are a pretty simple task if you have some mechanical know-how. Just pop the ball joints, tie rods and sway bars loose, remove the wheel bearings and transfer everything over. You'll want a big sledge hammer, or are hammer works better, impact gun, pry bars, etc. The hardest part I would say is popping the joints loose with out damaging the boot. Go onto google do a little searching and youll find everything you need to know.
