Aftermarket stereo
Old Jan 19, 2014 | 08:40 AM
Goofster08's Avatar
Goofster08
4th Gen Rams DOES NOT come with ACC turn on wire because they dont want people to change the stock head unit. Again only go this route if you have an ST or a SPORT or else you would need a PAC to connect the aftermarket stereo. The wire from the ACC key turn on (Should be on the driver side) that you need to tap to is bluish purple! Good luck!
