Whine
Old Aug 19, 2013 | 04:55 PM
sgonzalez1377's Avatar
sgonzalez1377
Default Whine
Engine all of a sudden started whining on my 2012 1500 4x4 with hemi . Not low on power steering fluid either
Old Aug 19, 2013 | 05:06 PM
nolimits's Avatar
nolimits
I'm sure it's an accessory/pulley/belt somewhere. You'll have to see where the noise is coming from...otherwise all anyone can do is make completely random suggestions. Too many possibilities for that method!
Old Aug 20, 2013 | 11:47 AM
sgonzalez1377
Yes u are right to many possibilities just need to eliminate one at a time thank you for your response
Old Aug 21, 2013 | 10:32 AM
DodgeCACares's Avatar
DodgeCACares
Sgonzalez1377,
As nolimits advised, there are too many variables involved to properly assess the vehicle through the forum. What's the mileage on the vehicle? Does it have any remaining warranty?
If you would like to review warranty information or have any inquiries getting the vehicle diagnosed by a Dodge dealer, please PM me and I'd be happy to help.
Old Aug 21, 2013 | 02:34 PM
LVRR's Avatar
LVRR
Most likely the whine will be your power steering pump, pulleys and belts tend to squeak or grind.
Since you are a 2012 you should still be under warranty. If so take it in and let Chrysler handle it.
Old Aug 21, 2013 | 03:32 PM
nolimits's Avatar
nolimits
All my whining noise comes from the back seat. Seems to go away when the kids aren't back there.
Old Aug 23, 2013 | 07:25 AM
BULLRAM's Avatar
BULLRAM
almost all the sound I have found was the idler pulley, not the tensioner pulley, this one sounds just like the P/S pump going out but if you turn the steering wheel the sound doesnt change, I have swapped out 8 of them on different friends trucks now, even my dads grand caravan 2010, has the exact same pulley ,and his did it, we swapped it out, and all is good, the dealer i went to changed out my P/S pump , and resorvoir, back in 2010 that didnt fix it so I started looking. the pulley is about $12.00 at Napa.
Old Aug 24, 2013 | 08:55 AM
sgonzalez1377
Cool
Yes You are right about the idler pulley BULLRAM . NO more Whine Thanks for all the Help
Old Aug 25, 2013 | 09:41 AM
LU229's Avatar
LU229
Great info...!!!!
Old Aug 25, 2013 | 01:36 PM
Pedro Dog's Avatar
Pedro Dog
A trick I use to isolate noisy pulleys is to get a spray bottle with water and spray the pulley while running and making the noise. The water will make the noise go away temporarily.
