2010 Ram 2500 5.7 Tire pres. mon.
Old Aug 23, 2013 | 08:08 PM
quickhitch11's Avatar
quickhitch11
Default 2010 Ram 2500 5.7 Tire pres. mon.
One of the guys here at work has the above truck, 2010, 2500, 50K on it, with the 5.7 v8. His tire monitor displays "pressure Low". It shows 58, & 59 psi on the front, and 60 psi on both rears. The two rears are flashing, not the fronts. I scanned it with my Verus, and found only one Active Code C0077-00, Low Tire Pressure. I looked at the door and adjusted the rears to 65, and then 70. I watched the dash, and my scanner and the pressures adjusted ok. When lowering the pressure the left rear is slow to drop, but rises the same as the right rear. i tried to clear the code, but it will not clear. Also tried to turn on and off the light / heavy switch, but it tells me it cann not change to light untill the pressures are adjusted. Any thoughts??? Thanks in advance, Chris
Old Aug 23, 2013 | 09:07 PM
bittergouldy's Avatar
bittergouldy
1- inflate tires to higher of the values from the sticker
2- drive it until the low pressure warning resets
3- hit the light load button & then you can adjust tire pressures to lower psi
Old Aug 24, 2013 | 06:15 AM
Rocknfire's Avatar
Rocknfire
Fronts at 60. Backs at 70. Drive till light goes out. Light load button allows backs to be set at 45.
