Aluminum Wheel Corrosion
Old Nov 16, 2013 | 12:01 PM
thirdjeep97tj's Avatar
thirdjeep97tj
Default Aluminum Wheel Corrosion
Anybody ever seen this/know how to fix it? Just put new tires on them and they had been sitting up for a while.
Attached Thumbnails Aluminum Wheel Corrosion-photo-3.jpg   Aluminum Wheel Corrosion-photo-2.jpg
Old Nov 16, 2013 | 07:20 PM
POWER SEDAN's Avatar
POWER SEDAN
That's the clear coat separating, somewhat common with aluminum, alloy wheels with all manufactures. Only fix there is to strip/sand the clear coat, and reapply.
Old Nov 17, 2013 | 12:49 PM
B.Kaiser1's Avatar
B.Kaiser1
That actually is very simular to a type of corrosion that can occur on aircraft aluminum parts, usually the skin. It is referred to as "Filiform corrosion".
http://www.corrosionclinic.com/types..._corrosion.htm
Old Nov 19, 2013 | 09:56 PM
duke07's Avatar
duke07
This can give you ideas on how to deal with filiform- http://www.airforums.com/forums/f381...orm-48503.html
Old Nov 22, 2013 | 01:03 AM
LU229's Avatar
LU229
Welcome to the world of....MADE IN CHINA....!!!!
You`ll never stop it from happening... sand it down and re-clear coat it.
