2013 keyless Memory Settings to KEY FOB
Old Dec 5, 2013 | 11:37 AM
Hanadarko's Avatar
Hanadarko
Default 2013 keyless Memory Settings to KEY FOB
On my 2013, Here is what I was told to do:
First - Make sure option in Uconnect is set to save personal settings.
1. With keyless ignition set to ON (but not running) adjust mirrors and radios and seats to where you want.
2. Press the S on the side of the seat and then press 1 or 2. In my case, I pressed 1.
Dash and radio said "Settings Stored)
3. Turn off keyless ignition
4. Press S then press 1 or 2 to 'recall' settings.
5. Within 10 seconds press LOCK on the FOB you want to link all of this to.
..ok, I did that but I didnt get or see any confirmation in either the dash or Uconnect windows. Just the turn signals flashed, which they do when you lock the door anyway.
The manual doesnt say either way that something should or shouldnt happen but how do I know it saved it to the FOB w/o feedback of some type or if I am even doing it right?
Old Dec 5, 2013 | 09:08 PM
WESIDE's Avatar
WESIDE
Well adjust the seat differently, then lock it, then unlock it and see if the seat moved to you prefered location?
