New 2014 1500 A/C Glitch / Software issue??
Old Dec 19, 2013 | 11:19 AM
omextreme's Avatar
omextreme
Default New 2014 1500 A/C Glitch / Software issue??
My New 2014 1500 has a glitch and I am wondering if its something I should let dodge look at or if it is common on other trucks.
8.4" uconnect / no Nav
When i have the a/c set to blow out the dash front vents and floor vents at the same time the dash vents dont work after shutting off engine and restarting. If i restart the truck the dash vents stop until I select another mode on the touch panel, IE defrost then select the dash/floor mode again. Once i do that they blow just fine until i restart the engine...
Thoughts? Should i just take it to dodge and let them deal with it?
Hate to take it in to shop with only 400 miles on odometer...
Old Dec 19, 2013 | 01:30 PM
LVRR's Avatar
LVRR
It is up to you and how high up on your aggravation meter it is.
If it is not that bothersome and you don't mind it that much then wait for when you bring it in for your first oil change. If it annoys the heck out of you bring it in.
Sounds like it may need a reflash or as in some cases for some problems it may be the radio and it will have to be ordered to be replaced.
Your call.
