Alpine audio system need Help and advice
Old Jan 30, 2014 | 06:54 PM
roadking801's Avatar
roadking801
Exclamation Alpine audio system need Help and advice
OK so this truck has this (so called ) nice truck Stereo. I do like the Head unit but the sub, sub amp speakers all sound like Pooooh. I have a set of JBL 5.25 componet set with a re audio 10 sub and two brand new amps one for the sub and one for the door speakers. So i go to the local audio shop and the guy tells me depending on which radio I have weather or not I must keep the stock amps then run into a converter or just bypass them and run to the converter. If you have any advice please let me know this is a 2011 Laramie system with I believe 8 speakers. I have no idea where the amps or amp is located
Old Feb 1, 2014 | 08:03 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct section.
For future reference, please read the below rules:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Feb 2, 2014 | 07:16 AM
02Regcab's Avatar
02Regcab
I could be wrong on this but as far as I remember the AMP is located under the steering wheel behind the fuse panel, Also I believe the Sub amp and speaker amp are one unit, but the Sub being a dual voice coil will need two line out converters if that's the route your going,
