hid low beam problems
so i hooked up in my buddies truck, a 2012 dodge ram 1500,led turn signals, low and hi hid conversion kits. now i have a fuse, relay with the hi black and red stock wiring for the highs going back to the relay and from there the ballast connections for those are shared by a split connection with one warning canceller. they are 55w ballasts and the hi beams work fine. the lows however are where i have my problems. they are a 35w ballast but there is no relay put for those. i have the power directly hooked to them through the stock wiring harness for each individual low. from there they each have a warning canceller then go into the 35w ballast and then to the light. the lights will turn on and stay for a few minutes but then you start the truck and turn the light switch from auto to on and they stay turned off. i tried wiring a 60w resistor with just the driver low connected just before the canceller and the problem persists. the light will sometimes be on and then turn off. the ballast seems to be cycling and i cannot figure out how to correct it. can anybody help? its a 4 lamp set up
