E-brake sagging
Old Jun 5, 2014 | 10:21 PM
edelsite's Avatar
edelsite
Default E-brake sagging
I have a steep driveway so I have to use my parking/emerg brake everyday. From daily use, either the cable is stretched or the brakes are worn enough to let the cable hang down under the truck about 2" lower than they're supposed to. I didn't see any obvious tensioner adjustments. Anyone know how to adjust the slack out of the cable?
Old Jun 6, 2014 | 12:50 PM
dirtydog's Avatar
dirtydog
Moderate User
On my quadcab '08, there is an adjuster on the intermediate cable about halfway in the middle of the rear door.
Maybe yours is on the pedal itself on the inside of the truck?
Old Jun 6, 2014 | 02:32 PM
Pedro Dog's Avatar
Pedro Dog
the adjuster is right where dirtydog said. I don't see how you can miss it if you just crawl under the truck. very easy to adjust
Old Jun 6, 2014 | 03:46 PM
oldjeep's Avatar
oldjeep
Doesn't seem like the inner cables stretching would cause them to hang lower, the jacket should still be the same length. You sure that something that holds them up didn't come loose?
Old Jun 6, 2014 | 05:26 PM
dirtydog's Avatar
dirtydog
Moderate User
oldjeep, the only thing that holds them up are the eyelets and tension. I think he means the entire unit hangs, not that the cable is pulled from the jacket....
At least that's how it read and how I took it.
As for the adjustment. I would recommend adjusting once. If you find yourself needing even more adjustment in the future, it's best to replace the cables.
Old Jun 12, 2014 | 11:49 AM
geener's Avatar
geener
I had this happen to my truck as well . I found the little pivot arms that actuate the mini brake shoes for the emergency brake were seized. the engine is so powerful you won't notice the e brake grabbing a bit. I hope this helps!
Old Jun 13, 2014 | 02:36 PM
dirtydog's Avatar
dirtydog
Moderate User
hmm. yeah, that can definately happen but generally it does when you rarely use them. OP said he uses them everyday. Not to say it isn't his problem, would just be odd. They generally seize up from little to no use.
I guess he could have spring mech problems and a little bit of rust forming not allowing the weak spring to retract fully!
