35's on 17" TKO's need spacers/adapters?
Old Jun 26, 2014 | 11:04 PM
Honey Badger Hemi's Avatar
Honey Badger Hemi
Default 35's on 17" TKO's need spacers/adapters?
Hey everybody,
I have read quite a bit about how 35" tires on 20" wheels with stock backspacing requires 1/4" spacers. What I have not found, is if the same is required for 17" wheels with stock backspacing, or if adapters would be needed. 2012 ST 4x4. Wheels are MB TKO 17" +18. Also, if I do need adapters, what is the minimum size needed to eliminate cutting the factory wheel studs? I've been researching adapters, and have been looking at the BORA adapters. good quality? Thanks everybody!
Old Jun 27, 2014 | 12:06 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Go with 37s, pull out the dremel, and do some wet-work. Lol!
You forgot to mention that your TKOs are 8.5" in width. Much love.
