Help led halos and low beams are dim
Old Aug 11, 2014 | 03:14 PM
nagggs1381's Avatar
nagggs1381
Default Help led halos and low beams are dim
I recently installed some Spyder LED Projector headlights on my 2011 Ram 1500. I drove them at night a couple times and thought that the Low Beams are dim even with the HID 6000K lights. Also I thought the LED halos are not very bright either. I thought I had wired them correctly but maybe I missed something...just wondering if anybody else has had this problem?
Old Aug 12, 2014 | 11:44 AM
02Regcab's Avatar
02Regcab
Gotta go CCFL if you want the halos to be bright like OEM cars example BMW, LED versions aren't nearly as bright, as far as the projectors use the screws in the back of the housing to adjust them to project farther, from the factory they are almost always aimed straight down..
Old Aug 13, 2014 | 08:14 AM
nagggs1381's Avatar
nagggs1381
ok great thanks. Do you know if there is an easy way to switch out the LEDs to CCFL?
