Need advice on wheel offset/Bs
Old Dec 15, 2014 | 08:38 AM
Arctodus's Avatar
Arctodus
Look Roll, go get your 20x9's but get them with a 4.5" backspacing and you shound be good to go. A spacer is going to put more pressure on your ball joints and make them wear out quicker than usual.
Old Dec 16, 2014 | 01:43 PM
rolltidehemi's Avatar
rolltidehemi
Matt,
I ordered 5/16" (8mm) spacers, gonna get tires done Sat, there is also 10mm which is little bigger than 3/8", T6 alum all hubcentric!
Old Dec 16, 2014 | 01:51 PM
rolltidehemi
Same with rims bro, they put an additional load on the front suspension and steering, pavement princess, live in SoFlo, pull a boat. This is a short term <3 mo soln until I can get the cabbage for some 20x9 fuel hostage rims with -12 offset, means to an end not permanent solution, but thanks for advice can't pony $2500 in one shot this time of year, have other expenses like GI Joe with the Kung Fu Grip!
Old Dec 16, 2014 | 01:52 PM
rolltidehemi
Post a pic of ur 4th gen Arct
Old Dec 31, 2014 | 05:24 PM
rolltidehemi
Had the 35 Terra Grappler G2s installed $358 a tire out the door with a hubcentric 5/16 spacer, no clearance issues, took a trip to Tenn from Miami through heavy rain on highways and mountains and couldn't be anymore happy with tires, had to check and re-torque lugs but after 3rd check they have been set!
Old Dec 31, 2014 | 05:28 PM
rolltidehemi
