Windshield Washer Idiot Light won't turn off.
Old Oct 16, 2014 | 02:43 PM
Millgirl's Avatar
Millgirl
Default Windshield Washer Idiot Light won't turn off.
Is the Windshield Washer Idiot light something I can reset myself on my 2011 1500 without taking it into the dealer? The fluid level was low, then I refilled it & the light stays on.
Old Oct 16, 2014 | 03:05 PM
If you have checked the connections on the sensor and looked at the sensor itself and everything seems ok, then disconnect the battery for a bit.
Old Oct 16, 2014 | 03:17 PM
BigBlueEdge's Avatar
BigBlueEdge
Are you using standard windshield washer fluid or the Rain-X stuff? The Rain-X stuff has been noted to cause sensor issues. Clean your WWF reservoir sensor and switch to standard and it will be fine.
Rob
Old Oct 17, 2014 | 01:32 AM
NV290's Avatar
NV290
I had issues on my 06' and my 11' Ram's with this exact issue. Both times it was the same cause, Rain-X orange washer fluid. If that is what you are using you have three choices.
1. Ignore the light and keep using Rain-X
2. Use up or drain the Rain-X Orange stuff and refill with any blue washer fluid and the light will go off and stay off.
3. Remove the sensor and solder a wire across the two tabs and you can use Rain-X all you want with the understanding that you will never get a low fluid light ever again.
If you are using regular blue washer fluid and have the light stuck on the sensor replacement is easy. Just a simple plug. And the price is beyond cheap. How does $2.56 with FREE shipping for a Mopar factory part sound?
http://www.ebay.com/itm/Washer-Fluid-Level-Sensor-Front-MOPAR-5152029AB-/261535878784?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce4c0ce80&vxp=mtr
Old Oct 18, 2014 | 02:12 AM
cyclone429's Avatar
cyclone429
when add washer fluid light is on I know I have washer fluid... When off I know to add fluid...My 06 has many issues with warning lights, all I do is check engine vitals my self and turn up my dual cherry bomb glass packs.
Old Oct 18, 2014 | 02:27 PM
dirtydog's Avatar
dirtydog
Moderate User
Either a 100 Ohm or a 4k resistor in the pigtail should fix your warning permanently. I'm not sure which way the resistance swings on your truck when full...
Old Oct 19, 2014 | 04:37 PM
Millgirl's Avatar
Millgirl
Oh Buggar... The Rain-X orange is the exact stuff I use, but I have been using it since I got the truck a few years ago, so that's weird... THANK YOU for the responses & help on this one!
