hide a switch to unlock 2014 ram 2500
Old Nov 19, 2014 | 12:57 AM
jerryjerryjerry's Avatar
jerryjerryjerry
Default hide a switch to unlock 2014 ram 2500
i never carry my keys r fob at work. I have a 2014 ram 2500. Is there a way to hide a push button on truck that would connect to power locks and unlock
door. Thanks
Old Nov 19, 2014 | 09:27 AM
oldjeep's Avatar
oldjeep
You would be better off adding an aftermarket keypad entry to the truck. Otherwise why not just leave the truck unlocked, eventually someone is going to see you hit the button.
Old Nov 19, 2014 | 11:43 AM
NV290's Avatar
NV290
It would be FAR easier and cheaper to hide a key. No chance whatsoever of having any wiring issues. Tapping into the unlock wiring is not so complicated, but I'm not sure how to hard wire a switch that would simultaneously disable the alarm and then unlock the doors. If you don't disable the alarm first then the alarm will go off every time you hit the switch and you would then need the fob to reset it.
This makes it simple:
http://yhst-55282638207197.stores.yahoo.net/info.html
Old Nov 19, 2014 | 10:18 PM
POWER SEDAN's Avatar
POWER SEDAN
Not to mention, anything tied to the security system via "hidden convenience button", will not allow the doors to lock with the key fob within the cabin of the truck.
