Help!! Remote locks and Wiper fluid jets not working
4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
So A couple of months ago, I started having all kinds of issues... after doing some research I found out that some water had gotten into the TIPM (Fuse Panel Computer) I replaced it and everything started working again..... except 2 things. The Keyfobs lock and unlock, and washer fluid jets. When you press lock and unlock, the lights flash so its receiving the signal, but that's it. and the jets, there is not noise or anything coming from them when I try to use them... Any help would be appreciated. Thanks!
the TIPM was brand new, and what do you mean by configuration restored? I know that on new TIPM's it will auto program itself with series of ignition turns.
