4th gen 2500 diesel chirping while accelerating
Old Mar 26, 2015 | 03:21 PM
Sdecker's Avatar
Sdecker
Default 4th gen 2500 diesel chirping while accelerating
I have a 2010 ram 2500 diesel its standard and when I take off and release clutch there is a chirping noise coming from front end somewhere if I push in clutch it's gone if I step on throttle it's back only happens from takeoff to mybe 40 mph what could this be I replaced wheel joints last year? Could it be my clutch or belt?
Old Mar 27, 2015 | 01:04 PM
Whiteout08's Avatar
Whiteout08
Does it only do this while the turbo is building boost? Is there a certain RPM range when it occurs or throughout the entire power band? I've seen this before where a turbo has issues, and the impeller veins actually rub the housing slightly.
Old Apr 1, 2015 | 10:05 PM
Largefarva's Avatar
Largefarva
Chirping noise is usually u-joints, you can often see which one is noisy because it will have bright-coloured rust around the cup of the joint where it meets the cross.
