level and lift question
Old Apr 2, 2015 | 10:30 PM
texas_rebel_1980's Avatar
texas_rebel_1980
Default level and lift question
I'm getting a 2.5" level on Monday. If I put the adjustable bilstein shocks in addition to the leveling kit, would it lift the truck as well?
Old Apr 2, 2015 | 10:49 PM
Arctodus's Avatar
Arctodus
Yes, it will lift the front 2.5". It won't do anything for the rear.
Old Apr 3, 2015 | 07:20 AM
Whiteout08's Avatar
Whiteout08
It will only lift the front if you set it that way...but why would you get both? There isn't any reason to get a level spacer AND adjustable shocks, just do one or the other.
Old Apr 3, 2015 | 08:06 AM
Arctodus's Avatar
Arctodus
Sorry, didn't read the question thoroughly, Whiteout is correct. And if you are trying to decide between one or the other, I recommend the Bilstien's.
Old Apr 3, 2015 | 08:08 AM
Arctodus's Avatar
Arctodus
Whiteout, we have the same truck and I see your mods, why did you also go with Mevotech upper control arms?
Old Apr 3, 2015 | 11:18 AM
Whiteout08's Avatar
Whiteout08
Basically I did this as a "better safe than sorry" situation. I have heard some people say their ball joints separated when adding a level kit to a late 2013 or 2014 RAM, so for the $70 it cost me to buy the Mevotech UCA's, I figured why not. I must say, they did improve my front end handling...when I hit a bump now, there isn't as much "hop" and the ride isn't nearly as rough/stiff. They are great quality..only down side is they are not a sealed ball joint, so they need to be greased once in a while.
Old Apr 3, 2015 | 11:27 AM
Arctodus's Avatar
Arctodus
Sounds good, did you install them or pay, and are they beefier than the stock ones?
Old Apr 3, 2015 | 12:11 PM
Whiteout08's Avatar
Whiteout08
I had them installed when I had the front level spacer put in, since it had to be taken apart anyway they just did it at no charge. I don't really recall the measurements but yes they are much more robust in design than the OEM UCA's. Definitely a worthwhile upgrade, especially for the price.
I feel like the only thing I need now to compliment the level spacers a bit further is a set of new "thicker" sway bars in the front and rear.
