how to convert quad to dual headlights?
Old May 8, 2016 | 10:09 AM
Arctodus's Avatar
Arctodus
Am I weird for noticing out of all that is in the picture the guy behind the door wearing a sandal on one foot and a shoe on another?
Old Jan 20, 2017 | 05:07 PM
Tpasterik's Avatar
Tpasterik
After you converted the lights from quad to dual and using the stock plug that's already on the truck do you have any warning lights pop up?
Old Jan 23, 2017 | 08:19 AM
That's not a guy.....
Old May 9, 2017 | 02:39 PM
14ramVincenzo's Avatar
14ramVincenzo
Default 2014 quad to dual headlight conversion
Has anyone done this on newer rams?! Have found a few that did it pre 2012s but nothing newer. Is it still the same?
Old May 10, 2017 | 06:13 AM
coldsteel's Avatar
coldsteel
Is the newer headlight a dual-filament bulb? Where's the high beam?
Old May 10, 2017 | 08:31 AM
14ramVincenzo
Yes dual filament from what I have been reading! Just got a couple answers back and said switched out no problems
Old Jul 18, 2022 | 01:10 PM
Hemi5.7berta's Avatar
Hemi5.7berta
Default Question
Originally Posted by whiteknight312
well, I converted the quad to the single bulbs with ease! its so simple. unplug the quad light harness from the green plug, then push the green plug end into the back of the headlight bulb. the headlight bulb has the plug end built into it. so you lock in the bulb on housing and push the green plug on and it all works. so nothing is needed, no harnesses, no cutting of wires. just plug and play. WOW! I was so happy because now I can return the stuff to dodge that I bought. I thought I would need pigtails and all sorts of harnesses. those cost me 90 bucks a side (if I needed them)! Now I get my money back. only thing that set me back were the bulbs.
Chris
i was wondering what bulbs did you use and ypu unplug the harness that has the high and low together and plug the new on in from the main harness?
