Changing spark plugs on 2015 HEMI
Old Aug 23, 2015 | 02:24 PM
dpracing57's Avatar
dpracing57
Default Changing spark plugs on 2015 HEMI
I wanna put in E3 plugs in my truck but the drivers side valve cover is under the damn brake booster, passenger side doesn't look much easier, is there a trick to getting these coil packs off and changing the plugs ? Thanks in advance.........
Old Aug 23, 2015 | 02:42 PM
Pedro Dog's Avatar
Pedro Dog
you have 100k mile plugs and you want to change them to E3 plugs? Anyway, there have been many reports that E3 plugs cause problems in the Gen 4 hemis engines.
To answer your question, use a universal joint extension right at the plug socket and then a short extension. The universal is the only way to get the socket in and the plug out.
http://www.autozone.com/ratchets-soc...l-joint-socket
Old Aug 25, 2015 | 06:28 PM
dwaldmann's Avatar
dwaldmann
If you have a real good reason to change the plugs, I would assume you'd also have the skills to change the plugs. Or at least the dollars to buy a manual.
Really??
Old Aug 28, 2015 | 07:00 AM
Whiteout08's Avatar
Whiteout08
I agree with these guys, why the heck are you changing the plugs already? Especially when the plugs you are planning to put in aren't any better than what's in there now. Leave it alone.
What's the reason for wanting to change them?
Old Aug 28, 2015 | 11:07 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
If it isnt broke or needing maintained, don't fix it!
