Push Pin Tool.
Old Aug 24, 2015 | 01:29 PM
John Valdes's Avatar
John Valdes
Default Push Pin Tool.
Well I decided to take a look myself at the windshield washer tank/hose to see where the river is coming from.
The felt material that surrounds the top of the engine compartment is attached with push pins. I must remove at least one to clear the tank.
Since I do not want to destroy the pins, I looked and I and see they make a tool for this. Don't get it. Looks like any thing to pry it up would work the same.
How does the tool get behind/under the top of the pin and squeeze the pin together for removal?
Or should I just pull them off and get new pins?
I rarely touch anything like this, but cash is king today and I'm trying to keep as much as I can.
Old Aug 26, 2015 | 05:24 PM
Whiteout08's Avatar
Whiteout08
Are you talking about the kind where the center comes out first then the entire pin pulls out? If so, go buy a trim removal tool set from Harbor Freight, they are designed to remove pins like this.
Old Aug 27, 2015 | 02:35 PM
John Valdes
I have no idea. Thats why I asked.
They are all along the interior edges of the engine compartment. Black plastic push pins holding the felt like material.
I have looked at the tools and my question was "how does this tool squeeze the pin to allow removal"?
The tool just looks like its for prying.
I will check the "set" as the tools i have seen are not removal sets. Its a single tool for prying.
Old Aug 27, 2015 | 03:13 PM
I just use a flat blade screwdriver to get uner the edge to start it, then a pair of large wire cutters to get under both sides and pry it out.
These work better, but I like to Mcgyver things.
http://www.harborfreight.com/6-piece...set-66188.html
Old Aug 28, 2015 | 06:58 AM
Whiteout08's Avatar
Whiteout08
That set will work fine, I've just never liked to use anything metal when prying parts off a car, this is the one I have and would hate not having it.
http://www.harborfreight.com/5-piece...set-67021.html
Old Sep 1, 2015 | 11:14 AM
Duso02's Avatar
Duso02
Agreed. I have the same set in my toolbox. Plastic doesn't scratch. If it is just a plain one-piece head, slide the fork under and pry it up. If the head is two pieces, a wide washer looking part, then a smaller flat top version in the center, pry the smaller one up then pull them both out together.
