Tires size for a 2.5" lift
Old Nov 9, 2015 | 02:14 PM
ealemany's Avatar
ealemany
Smile Tires size for a 2.5" lift
Hi
I have a 2012 Ram 1500 4x4 (5.7L) I am planning to install a 2.5" lift kit.
the current tires on the OEM rims are 275 / 60 / 20.
What are the largest tires (diameter) i can put on the OEM rims with a 2.5" lift?
Thank you for your help.
Eric
Old Nov 9, 2015 | 03:25 PM
badjojo13's Avatar
badjojo13
Originally Posted by ealemany
Hi
Eric
I have just put lt285 65 r20 bf goodrich all terrain ko2 they give 35'' diameter by 11.2 inch they look good very minor rubbing when fully turned .
if you want a more agressive look 35x12.5 would look better but factory wheel may need spacer's witch is not recommanded . You whould be better with a diffrent rims with a diffrent offset
Old Nov 9, 2015 | 04:09 PM
ealemany's Avatar
ealemany
Default Thank you
Thank you Badjojo13 for your recommendation. I would like to stay with the OEM rim. They look nice and i don't have to spend extra money.
I just looked at the BF Goodrich tire and they would look good.
I also looked at the Dick CEPEK Fun Country they might look good too.
Anyway, thank you.
If / when you get a chance do you mind taking a picture of your truck so i have an idea of the look - you don't have to if you can't.
Thanks again.
Cheers
Old Nov 10, 2015 | 08:25 AM
badjojo13's Avatar
badjojo13
pictures here not ther greatess but thats what i have
https://dodgeforum.com/forum/4th-gen...a-fitting.html
Old Nov 13, 2015 | 09:57 PM
iwhitne's Avatar
iwhitne
you should be safe up to a 295-65-20.. this will give you a 35" tire but only 11.61 wide.. so it won't rub on the A-arm..
