Key Fob Issues
Old Apr 10, 2016 | 01:46 AM
thebusiness11's Avatar
thebusiness11
Default Key Fob Issues
Just picked up a 2010 Ram 1500 and it only came with one key and no fob. The dealer said this car may have not have ever had a fob and that I would have to get an aftermarket keyless entry installed. Is there a way to check and see if there was ever a key fob and if so how would I go about replacing it?
Old Apr 10, 2016 | 07:18 AM
You can go to this site and request your build sheet. That will tell you.
If you don't currently have an FOB, a dealer or locksmith will have to do it.
http://www.dodge.com/webselfservice/...ull&category=U
Old Apr 11, 2016 | 09:16 AM
DodgeCares's Avatar
DodgeCares
thebusiness11, if you’d like to PM your VIN, I can also check on the FOB issue for you.
Kori
Ram Social Care Specialist
Old Apr 12, 2016 | 03:17 AM
thebusiness11
Kori
Hey thanks for the offer but I followed the advice earlier in the thread and ordered the build sheet. Turns out it never had a keyless entry system installed. Now I am trying to find the best route to have this installed after the fact.
Old Aug 25, 2016 | 03:43 AM
ictsean's Avatar
ictsean
if you have a 2009 or newer ST model that came without keyless, you can still add keyless. go to YouTube. look for a video called "EASY and CHEAP - How to Install Factory Keyless"
this should help you out.
