interior water leaks
Old May 10, 2016 | 08:22 PM
cummins 6.7's Avatar
cummins 6.7
Default interior water leaks
hey fellas
i have a 2010 dodge ram 2500 6.7 cummins
it recently started having water leaks inside when it rains...
it leaks from both front pillars and at the overhead console...
anybody have this issue? if so let me know any fixes or what exactly the prob was
thanks
Old May 11, 2016 | 11:44 AM
DodgeCares's Avatar
DodgeCares
Originally Posted by cummins 6.7
hey fellas
thanks
Is the water coming through the headliner? I’d recommend having your local certified FCA dealer conduct a leak test. Let me know if you need assistance establishing an appointment. – Kevin T, Social Connect Team
Old May 11, 2016 | 01:29 PM
cummins 6.7
not coming through the headliner but it is coming from the headliner edge and pillars and through head console
Old May 11, 2016 | 01:53 PM
DodgeCares's Avatar
DodgeCares
Thanks for the follow-up. I'd recommend establishing a dealer appointment for diagnosis and repair. Let me know if you're in need of assistance doing so. - Kevin T, Social Connect Team
Old May 11, 2016 | 08:06 PM
Duso02's Avatar
Duso02
Do you have a sunroof? Mine leaked at the pillar handles due to a clogged drain line from the sunroof. Runs from the front drivers side sunroof opening through a tube down along the pillar and exits the truck in the fender just forward of the upper driver door hinge. Others had the third brake light leak into the headliner.
Old May 12, 2016 | 07:23 PM
cummins 6.7
i do have a sunroof.
mine does actually leak at pillar handles and over head console. im gonna look at that
youre probably right
thanks
Old May 12, 2016 | 07:26 PM
cummins 6.7
and the third brake light leak i fixed
i thought i was the only one with that sorta leak
appreciate the info
thanks
Old May 14, 2016 | 08:46 PM
Duso02's Avatar
Duso02
Mine happened right after the warranty expired. Oh well.
Old Aug 20, 2016 | 09:37 PM
mlneal's Avatar
mlneal
Where is this tube located at the sunroof? My '15 2500 is doing the same thing, bought it new in February of this year. Getting nothing but run around from dealers. 55K on a truck and FCA won't take care of owners.
Old Aug 20, 2016 | 09:48 PM
cummins 6.7
there are two tubes
each front corner of the sun roof.
if you remove both front pillars youll see the tubes running down to the side of the cab when u open the front doors.
but i will mention, my leak turned out to be not in the sunroof but the top cab lights, the gaskets were no good anymore
hopefully that helps
