Can someone clear up the front gear swap issue on the 2014 1500 please!
Old Aug 6, 2016 | 05:29 PM
ledyard's Avatar
ledyard
Default Can someone clear up the front gear swap issue on the 2014 1500 please!
I have been searching Google for days and all i find is contradicting info. Then i remembered i was a member here when i had my gen 3 2500.
I have a 2014 1500 4x4 triple black crew cab. 6spd with 3:21. Seeing as i drive a lot the 3:21's don't bother me cause the mpg is better.
I just had new A/T's , 2.5" front level and a borla proXS done. Very happy with it.
But i still wanna lift it 5-6" and go 35" rubber. The problem is obviously is the ZF front diff.
Certainly im not going 35" tires with 3:21(or 3:55 for that matter) as that would be ridiculous. I'm a firm believer that 4:56 is mandatory with 35" tires. (Definitely was a great move on my 2500)
But 4:56 is not an option. So i have to think that running stock 33" tires with 3:21 gears would feel exactly the same as running 35" tires with 3:92 gears would it not???
So here's the real question.... all im reading is contradicting info the front ring gear is or isn't welded to the carrier?!!!!???
Old Aug 6, 2016 | 07:16 PM
Montands's Avatar
Montands
Are you planning on switching out the 3:21's with 3:92's? I know a guy with 35's and 3:21's with his Hemi. He seems to like it. Personally I have the Eco with 3:55's and I wouldn't plan on upgrading to 35's. I like the size of 33's, just with I had them on 17/18s.
Old Aug 6, 2016 | 08:04 PM
ledyard's Avatar
ledyard
Yes. IF the front isnt welded i WILL swap 3:21 out in favor of 3:92. There's no way i would ever run my current gear with 35". When i put 35" on my gen 3 2500 with 3:73 i was VERY unimpressed. I swapped in 4:56 two weeks later and it was just perfect.
For me, there is no question i would have to go 3:92. Considering there are no lower options.
Ill also add an OEM limited slip. I had a factory locker on my 2500 and it really blows not having one now.
Old Aug 7, 2016 | 11:19 AM
Arctodus's Avatar
Arctodus
You should be able to fit 35's on it now with a 2.5" leveling kit, I did. I have 35's with 3.55's and its not too bad. But you are correct in saying that the diff is welded and for that reason there is no changing to 4.56. I too went from 3.73's to 4.56's with my Megacab which also had 35" tires. Big difference.
Old Aug 7, 2016 | 02:29 PM
ledyard's Avatar
ledyard
So it IS welded then.
Ok. Ill just get some new rims and put 33x12.5x20 on it and stay as i am. The level changes the trucks appearance entirely and with a 12.5 wide tire that sticks out of the wheel well a little it'll look just as baddass. Just save my factory black rims and new 275/65/20 for winter. Now I'll just get the $1700 hammerhead bumper i want instead of all that lift /regear money
