2009 1500 2WD steering dampener ?
Old Aug 25, 2016 | 08:37 PM
WESIDE's Avatar
WESIDE
Default 2009 1500 2WD steering dampener ?
So I searched the internet a little and I cant seem to find any type of brace or dampener for the 2wd. I'm trying to eliminate the steering wheel jerk when turning and hitting a bump or pot hole. It can be pretty bad. I have seen a bracket adapter plate for the 3rd gens but nothing for the fourth. I have read changing the front struts help but there has to be something else out there for us by now. I only have 60k miles on it. Any suggestions or ideas. Thanks
Wes
Old Aug 31, 2016 | 07:57 PM
WESIDE's Avatar
WESIDE
bump....Anyone?
Old Sep 9, 2016 | 03:51 PM
oldjeep's Avatar
oldjeep
It has rack and pinion steering, how exactly would you install a steering dampener? I've got 136K on my 2009 and can't say that I've ever noticed the type of behavior you are describing.
Old Sep 10, 2016 | 09:25 AM
WESIDE's Avatar
WESIDE
www.dodgeramsteeringstabilizer.com
These are made only for the 3rd gens and can't seem to find anything similar for the 4th gens. I guess it would considered more of a brace/stabilizer. Rather than a damper. I think it's purpose is to eliminate the flex and movement of the rack. This was just a quick link I found but there are lots of company's selling these.
Old Sep 16, 2016 | 02:03 PM
huntergreen's Avatar
huntergreen
sounds like you have an issue. i would fix the issue rather than cover it up.
Old Sep 16, 2016 | 08:05 PM
WESIDE's Avatar
WESIDE
Good point. Maybe there is an issue. Now that I think about it seems more noticeable when going though a left turn curve, though it does occur going right as well. Was there a recall or TSB on tie rod ends? Where else should I look? Possibly the rack and pinion itself, bushings?
Old Oct 3, 2016 | 09:31 PM
WESIDE's Avatar
WESIDE
Does anyone know if an alignment issue would cause this? Would camber, caster or the toe make it hop and pull on bumps/potholes? Thanks fellas
