Coolant / Brake / Power Steering Flush
Old Oct 31, 2016 | 07:59 PM
dstone84's Avatar
dstone84
Default Coolant / Brake / Power Steering Flush
I have a 2010 Dodge Ram 1500 V8 Hemi with about 75,000 miles on it. I plan on taking it in for service this week and was wondering what do I need to have done. Last time I was at the dealership they mentioned I needed to flush my coolant fluid, a brake flush, and a power steering flush. Are all these usually all necessary?
Also, I recently had to get the radiator replaced after an accident. Therefore I am guessing I can skip the coolant flush because I am assuming it was done when the new radiator was installed.
Lastly, I am hearing an awful noise coming from the rear. My last rear differential service was at 50K miles. How often should i have the rear differential service completed?
Old Oct 31, 2016 | 09:41 PM
Read what is recommended in the owners maintenance schedule. Anything else offered by the dealer is unnecessary and us called "up selling".
Old Oct 31, 2016 | 10:40 PM
primem's Avatar
primem
do the transmission fluid..that is the most important....then driveline ie diff's and tcase then coolant.
brake fluid meh. every 2 years is what they want you to do it, its hydroscopic and will absorb water which lowers the boiling point and may corrode the system. If its never done; you will never notice. It looks nice when its clean in the reservoir. I do it cause it only costs me $7 but i would never pay somone 1 hour shop labour to do it.
p/s fluid... don't even bother
diff service all depends on your usage. when its dark or grey (from moisture), change it ....i would never go over 50 000miles.
