2012 Ram 1500 Driver side door lock actuator
Old Dec 29, 2016 | 06:12 PM
Donny125's Avatar
Donny125
Default 2012 Ram 1500 Driver side door lock actuator
My driver side lock is gone on my truck, it makes a machine gun sound and rapidly moves up and down before locking (and occasionally won't lock at all). I have ordered a new actuator and removed the door panel. Just curious if anyone else has replaced their lock actuator before. There aren't too many videos on replacing the lock on newer Rams. I am wondering if I have to remove the inner door panel to replace the broken actuator? I was told at the dealership I most likely will, however I watched one video where the guy did not. Any help is much appreciated.
Jon
Old Dec 29, 2016 | 06:26 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
You should be able to get it out through an opening in that carrier plate. At least I can anyway. The book says take it off.
Ret assured, this won't be the only one you replace so go practice (:
Old Dec 29, 2016 | 06:39 PM
Donny125's Avatar
Donny125
Thanks, ya the more I look at it, looks like I should be able to get at the lock through that opening.
Old Dec 30, 2016 | 02:54 PM
TNtech's Avatar
TNtech
It's the plastic bracket that is a separate part on the inside that prevents you from taking it out...conventionally anyway. I have a time limit but you have plenty of time to do it the right way and not break anything.
