Oxygen sensor run monitor
Old Feb 17, 2017 | 06:20 PM
CD3's Avatar
CD3
Default Oxygen sensor run monitor
I'm having trouble getting the O2 monitor to run so as to pass smog.. I've tried everything except changing the upstream sensors. Would a not bad enough sensor not throw a code or cycle the check engine light ? also, would a faulty O2 sensor cause it to not run the monitor ? 2010 5.7 with 214708mil. looking for any suggestions before I just switch the sensors.
Thanks,
Dom
Old Feb 18, 2017 | 06:58 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Without being able to see and diagnose O2 data, your only option is to change parts.
