Driver Side Mirror Control Issue
Old Apr 5, 2017 | 08:30 AM
02Flstfi's Avatar
02Flstfi
Default Driver Side Mirror Control Issue
I have a 2013 Ram 3500 and I just noticed yesterday that my driver side mirror control is 90 degrees off. By 90 degrees off I mean if I push down on the control button the mirror moves out, if I push out it moves up, if I push up it moves in and if I push in it moves down. Same with the reverse parking assist, where both mirrors are suppose to move down a little, the passenger mirror moves correctly however the driver side moves out.
Passenger side works correctly from the control button.
This just started happening with the last couple weeks as I know it worked correctly that last time I washed the truck and cleaned the mirrors. Had to readjust then then and they both worked correctly.
Any one else had this issue or have any ideas on what might be causing this?
