Blower Motor Super Noisy on low
Old Apr 13, 2017 | 03:17 PM
SeregaBeliy's Avatar
SeregaBeliy
Default Blower Motor Super Noisy on low
I recently bought a 2010 1500 hemi. Now that I drove it for a while, I noticed that blower fan is REALLY noisy on low speeds... Is that normal? or do I need to replace it? Where is it located to replace myself if needed? My model does not have the auto or dual control, Just regular ***** to control speed, temp and direction. Thanks in advance!
Old Apr 22, 2017 | 10:01 AM
Rado's Avatar
Rado
It is possible something is stuck near the fan, and it could be a bearing in the motor.. Not sure of location but usually in the area of the glove box ! If you have a cabin air filter have you changed it? I assume the 2010 have the cabin air filter but I am new to RAMs myself so not sure ! To check you need to take off the glove box, you may want to grab a manual . Hope the gear heads can give you better info
Here is a You Tube videos,, Not a 2010 but can give you a idea
