bullydog question
Old Jun 13, 2017 | 11:53 AM
badjojo13's Avatar
badjojo13
Default bullydog question
a friend of mind got ride of is truck a few is years ago and keep is tuner. he had put back the factory programed in the truck before selling it.
he had it on a 2010 ram 5.7 hemi same has me.
I have 2 question
1- he lost the cable to hook it up to the truck so can I buy just the wiring
2- will it work in my truck or do I need to by a license for my vin since it was once used in a other truck
thank you
Old Jun 13, 2017 | 12:46 PM
You will need the correct cable for that tuner to connect to your OBD port. If the tuner is unlocked, you won't need to buy a license.
Old Jun 13, 2017 | 02:41 PM
badjojo13's Avatar
badjojo13
how will I know if its unlock?
any idea's where I can find the cable?
Old Jun 14, 2017 | 07:55 AM
To check if it's unlocked:
1. Go to the Main Menu.
2. Scroll down.
3. Choose Show Settings.
4. Check to see what the tuner shows next to “Status”.
5. If it shows:
• Installed – the tune is still loaded on the engine computer.
• Not Installed – the tune has been uninstalled and the vehicle is returned to stock.
• Recovery – there is a problem and you should contact technical support.
Probably need to contact the manufacturer to get the correct cable.
