No power
Old Jul 5, 2017 | 10:35 PM
Jandrewdave's Avatar
Jandrewdave
Default No power
I have a 2009 ram 1500 4wd with 5.7 hemi
was driving it home parked in driveway was running fine.webt to leave a sgort time later and truck will not start.ebgine cranks will start with starting fluid but then dies.i pulled the fuel tank out ran a hot and ground wire directly from battery to fuel pump the pump kicked on tried it several times to makes sure also checked the only fuse i could find for the fuel pump and found to be good.i tested wire harness where it plygs into fuel pump no power i think i might have a tipm problem but not sure any info on this would be greatly appreciated thank you
Old Jul 6, 2017 | 07:26 AM
Punctuation would help.
Old Jul 6, 2017 | 12:58 PM
Pedro Dog's Avatar
Pedro Dog
look here,
https://dodgeforum.com/forum/4th-gen...y-running.html
