KEy Fob
Old Dec 21, 2017 | 03:02 PM
Justsayin's Avatar
Justsayin
Default KEy Fob
2009 Ram 1500 SLT, key fob will automatically roll down the windows and flash the lights even when in the house. I changed the battery, thinking that was it, but no, as long as the signal is getting to the truck windows roll down and lights flash???
Old Dec 21, 2017 | 06:11 PM
stealthgoat's Avatar
stealthgoat
sounds like you have a button on your fob stuck down.
Old Dec 21, 2017 | 06:22 PM
SHO Rod's Avatar
SHO Rod
^^^ Agreed.
If the keypad for your 2009 fob uses a membrane pad instead of having actual buttons soldered to the circuit board, over time the membrane pad absorbs finger oils and other debris and can actually allow the conductive pads on the membrane to transfer and stick to the contacts on the circuit board which would cause the symptoms you describe of a stuck Unlock button.
-Rod
