Another Key Fob/Door Lock Problem
Old Feb 8, 2018 | 04:05 PM
dahargis's Avatar
dahargis
Default Another Key Fob/Door Lock Problem
2010 Ram 1500 Quad cab, no remote start.
Key fob will not actuate any door locks. Had my fob tested. Battery was 1/2 life, but replaced anyway. Tested fob and it is sending a strong signal. the door lock and unlock buttons work fine. What do I need to look at next?
Old Feb 10, 2018 | 09:41 AM
SHO Rod's Avatar
SHO Rod
Do you have a second fob that you can try to see if it works? If it works, then you may need to re-bind your fob to your truck. If the second fob doesn't work, then you probably can stop focusing on the fob and switch to focusing on the module within the truck. Are there any other features of the fob that you can try, like maybe a panic feature?
-Rod
Old Feb 12, 2018 | 11:21 AM
dahargis's Avatar
dahargis
-Rod
Thanks, that is where I went with this. I tried my other fob and it works correctly, so the original fob needs to be reprogrammed or replaced. And no features work on the bad fob. I wish there were a less expensive route for reprogramming these things.
Old Feb 12, 2018 | 02:15 PM
SHO Rod's Avatar
SHO Rod
If you know someone with a high end scan tool they can probably program it. I have an Autel DS708 and an MT906BT and both have the capability to reprogram fobs and keys.
-Rod
Old Feb 15, 2018 | 05:46 PM
dahargis's Avatar
dahargis
-Rod
Thanks, but I don't even know what those tools are. Pardon my ignorance. I think I'm going to replace the bad fob. I don't want to pay to have it programmed to find it won't hold or accept a program.
