Need some Help with belt
Old Mar 10, 2018 | 11:50 AM
Damion5050's Avatar
Damion5050
Default Need some Help with belt
I have a 2011 Ram 1500 Big Horn with the 5.7L Hemi. About 2 weeks ago I was getting serpentine belt noise, so I replaced it. The belt was making noise at all times, when the truck was idle as well as under power. Well the noise stopped for about 3 or 4 days, and now the noise is back, but the noise does not happen all the time. The belt does not make noise at idle, but starts to make a whining noise at or above 1000 RPM's.
Thanks in Advance
Cody
Old Mar 11, 2018 | 04:58 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Thanks in Advance
Cody
Remove the belt and spin all the pulleys and see if they make a nose. This USUALLY indicates a water pump going out.
Old Mar 13, 2018 | 07:44 AM
jrsick's Avatar
jrsick
You should also check your belt tensioner. See if scribe mark is at the limit. Your belt would slip if the tensioner was not providing enough pressure.
