100k service
Old Apr 22, 2018 | 06:37 AM
Big had's Avatar
Big had
Default 100k service
2011 Hemi Motor. Auto trans. Transmission was serviced at 60k. Plugs were also replaced. I got lazy and haven’t truly stayed on top of this truck. It has 0 issues though. But here I am, sitting at 93k miles, 7 years old. Decided to get going on any required services. Yesterday I drained the radiator. Fluid was red. Replaced it with zerex G-05 fluid. It’s yellow. No issue there, right?
drained rear axle. Replaced it with Lucas full synthetic 75-140 and added dealer additive.
Replaced the PCV valve. The old one looked new still,and moved freely.
Replaced serpentine belt. Again, pretty amazed at how good the original one still looked. No cracks, no signs of nearing a failure.
Today going to replace front axle oil with Lucas full synthetic oil. I think it’s 75-90. I know it’s different from rear.
going to drain transfer fluid and add Napa +4 full synthetic trans fluid.
Am I using the right fluids guys?
what else should I be replacing?
the truck has always used Mobil one 5-20 engine oil which I replace every 5k miles. The air filter is clean. Recently did the cabin filter.
Any advice greatly appreciated. Fuel filter? Suggestions and feedback appreciated.
Old Apr 22, 2018 | 07:41 AM
As long as the fluids meet the specs listed in the owners manual, you’ll be fine. I’d also follow whatever maintenance is recommended by the manufacturer for the mileage. Can’t go wrong following the manufacturers recommended maintenance schedule.
