p108c code
Old May 1, 2018 | 01:21 PM
digr's Avatar
digr
Default p108c code
2015 ran 1500 with a code p018c code, Is this truck safe to drive?? My daughter in law is picking up the truck tomorrow and the check engine light came on today.
Old May 1, 2018 | 01:31 PM
It's a fuel pressure sensor code. It may be hard to start, sluggish to start and/or result in poor engine performance. Safe to drive? How is it currently running?
Old May 1, 2018 | 01:33 PM
digr's Avatar
digr
Thanks very much for the quick reply!!! It is running fine with lots of power,
Old May 1, 2018 | 01:38 PM
Clear the code and see if it comes back. If it's running ok, should be safe to drive. I don't guarantee anything though.
Old May 1, 2018 | 01:40 PM
digr's Avatar
digr
My code reader displays "code error" and will not clear
Old May 1, 2018 | 02:08 PM
how did you get the code then?
Old May 1, 2018 | 02:20 PM
digr's Avatar
digr
I used my code reader and it brought up the po18c code and it read non recognizable code
Old May 1, 2018 | 02:28 PM
https://www.obd-codes.com/p018c
Old May 1, 2018 | 07:02 PM
digr's Avatar
digr
I didn't have time to mess with it so I took it to a local mechanic and he replaced the fuel pressure censer for $216.36 which I didn't think was to bad, the dealer quoted me $85 for the part. I would have went for it myself but was afraid that it might be another problem and I would run out of time. Thank's for the help!
Fuel Pressure Sensor
Read more at: https://www.obd-codes.com/p018c
Copyright OBD-Codes.comFuel Pressure Sensor
Old May 1, 2018 | 09:10 PM
Glad you got it taken care of.
