high oil pressure
Old May 12, 2018 | 07:42 AM
kennys's Avatar
kennys
Default high oil pressure
2009 Ram 1500. Oil pressure constant at 96 lbs.
Old May 12, 2018 | 07:53 AM
How are you measuring that?
Old May 12, 2018 | 08:33 AM
kennys's Avatar
kennys
that's what the gauge reads in the dash. Could it be the Oil sending unit?
Old May 12, 2018 | 08:54 AM
true blue's Avatar
true blue
You could do a proper pressure check with a gauge, from the engine...However...I'm thinking if your oil pressure was that high, you'd have other symptoms as well. Its also not usual for the pressure to go up like that unless you have internal blockage somewhere or most likely a failed oil pump or possibly a bad oil filter. Did this problem begin just after your oil was changed?
Old May 13, 2018 | 12:40 AM
HemiLonestar's Avatar
HemiLonestar
1. Your 09 is a 4th gen, you're in the wrong place
2. More than likely is the sensor; are you getting code P0520 as well?
Old May 13, 2018 | 06:30 PM
kennys's Avatar
kennys
Default 4th Gen Ram Tech 2009 - 2018 Rams:
Thanks to all that replied. Think we fixed the problem. SENSOR.
