toeque specification
I don't have any information on the 2002 model year (which is a different generation than you've posted in here) but you will get better responses if you better specify which particular torque values you're looking for. I assume you mean upper "A" arm. Are you interested in the ball joint torque, the mounting bolt torque values, or something else altogether?
-Rod
-Rod
Go to this webpage: http://www.moparrepair.com Click on install Inf Requests and fill out the form with your needed information. they will email it to you in 24 hours. I did this when I need the torque specs for brake calipers and intake manifold.
