2012 Dodge Ram 1500
Old Jul 19, 2018 | 11:25 PM
Dwight02's Avatar
Dwight02
Default 2012 Dodge Ram 1500
My Dodge Ram has a 4.7 engine if I get in a little mud at work the engine just flutters and goes to a idle tries to rev up but won't no matter how hard I mash the gas pedal no warning lights and no codes on the highway runs good if I mash the pedal and kick in passing gear it will take off can anyone help.
Old Jul 20, 2018 | 07:56 AM
SHO Rod's Avatar
SHO Rod
I'm not sure I understand the scenario when there is an issue. What do you mean by, "get in a little mud at work"? Do you mean if you try to drive through an inch or two thick layer of mud the engine speed slows way down?
Does it run rough when it does this, or "idles" smoothly just like if it started and still in Park? How do you get out of the mud if it's basically at idle speed and the engine refuses to increase with throttle input?
-Rod
Old Jul 20, 2018 | 11:54 AM
Dwight02's Avatar
Dwight02
Yes I got stuck I could pull forward and then back up to work myself out and no power motor flutters and just idles down when idling down or on the highway motor runs good iveI never seen anything like that
Old Jul 20, 2018 | 01:56 PM
SHO Rod's Avatar
SHO Rod
Have you had any rain since this started happening to see if just high humidity or water on the roads will also cause the issue? It seems like it almost has to be related to moisture versus being under load. A moisture issue could be due to moisture in a connector, in one or more spark plug wells, or a wire with damaged insulation.
If this has only happened one time though, maybe someone set the parking brake and you didn't notice to release it, or maybe the issue is only when in 4WD (if your truck has 4WD), etc.
-Rod
Old Jul 24, 2018 | 09:24 AM
Duso02's Avatar
Duso02
Is there a difference with traction control on or off?
Old Jun 9, 2021 | 06:34 AM
DirkFA22's Avatar
DirkFA22
Sounds like they've set the idle too low on your computer program as well and when it tries to regain power it doesn't because it's gone too low so if you can reset all the values on the ram and ask the company for a version of software that has the proper idle control Target you can also replace your map sensor your PCV and your vacuum sensor on the brake vacuum booster when you reset the ram your value should bring back on the vacuum all the way and when they changed the version of software you'll have a perfectly running good truck
