2014 Ram 2500 Quad cab 4x4 5.7 hemisphere 4 wheel drive will not engage when engine r
Old Dec 28, 2018 | 12:47 AM
Mumbulog's Avatar
Mumbulog
Default 2014 Ram 2500 Quad cab 4x4 5.7 hemi 4 wheel drive will not engage when engine r
My 4 wheel drive was not engaging, 4 wheel light just blinks. We replaced the speed sensor and the 4 wheel worked once. Attempted to use it again, would not engage. We unplugged battery to reset computer, 4 wheel drive then worked again once. We played around with it and discovered that when the key is turned on and just before you turnover the engine, 4 wheel will engage, and you can turn it off while truck is running. But cannot engage 4 wheel while truck is running. ABS and traction control lights are on, traction control will not turn off.
thoughts/ suggestions?
Old Dec 31, 2018 | 08:20 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You have a bad sensor for the ABS
Old Jan 1, 2019 | 01:05 PM
Mumbulog's Avatar
Mumbulog
We changed the wheel bearing and that came with a new one, should I start with changing the sensor on the opposite side?
Old Jan 2, 2019 | 04:03 PM
MoparFanatic21
Have the codes read and it should lead you to the bad sensor, before you start throwing parts at it. From what I understand if the ABS light is on the truck won't allow you to engage 4wd. I could be wrong though.
