2014 Ram 4500 6.4 Hemi
Old Feb 17, 2019 | 03:48 PM
gjhamilton's Avatar
gjhamilton
Default 2014 Ram 4500 6.4 Hemi
As the title states the truck has developed a strange problem. At idle there are no issues until I try and accelerate. Once I do that the check engine light comes on as does the traction control and service electronic brake system message. The truck will buck and surge as shown in the video. It will
eventually die and not restart unless the key is removed from the ignition. Once restarted it will idle fine until the accelerator is pressed and the whole process starts all over. There was a code for cam sensor which was replaced but it didn’t fix anything. I’m hoping that someone can shed some light as to what’s going on. I want to thank everyone for their input in advance.
Old Feb 17, 2019 | 03:49 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Do you have a scanner they can see live data?
Old Feb 17, 2019 | 04:14 PM
gjhamilton's Avatar
gjhamilton
Yes I have access to one. What should I be looking at specifically?
