Differential Oil Change
Old Apr 8, 2019 | 08:29 PM
Eric Buchholz's Avatar
Eric Buchholz
Default Differential Oil Change
I have a 2011 Ram 1500 and I am planning to change the differential oil. When I look at the back there is a plug on the bottom and then one on the top. Can I just drain it out the bottom and add oil in the top? Not sure if I need to take the cover off and clean it out or not?
Old Apr 8, 2019 | 09:41 PM
Yes. Drain and refill using the plugs.
Old Apr 8, 2019 | 09:46 PM
Eric Buchholz
Thanks for the reply. So you don’t think it’s necessary to take the cover off to clean out? Just drain and add?
Old Apr 8, 2019 | 10:38 PM
Personally I wouldn’t.
Old Apr 8, 2019 | 11:30 PM
00t444e's Avatar
00t444e
I always remove the cover and clean everything out when I do a gear oil change.
Old Apr 9, 2019 | 06:49 AM
ramsportrocks's Avatar
ramsportrocks
depends on the mileage.. 80 to 100K I would pick up a gasket and do the cover, wipe out the diff with rags and brake clean.. should be a magnet in bottom .. clean metal off of that
and good to go less than that I would get it good and hot on a drive and just pull the plug
Old Apr 9, 2019 | 04:14 PM
Eric Buchholz
Thanks for the help everyone. I plan to change the transfer case fluid as well. I have 150k on the truck and mostly use it for hunting. I cant say I put a lot of hard miles on it. Do you think I need to change the transmission fluid and filters as well?
Old Apr 12, 2019 | 10:06 PM
Johnny Almeida's Avatar
Johnny Almeida
Definitely, i would do the transmission every 40k miles. I have a 2011 and been going by the manual for intervals. It's my wife's truck and it normally goes to the dealer for everything but I did the rear end myself. I did the fluid only since it only had 45k.
Old Apr 21, 2019 | 10:38 AM
Eric Buchholz
Changed the rear differential oil and it was a pretty smooth process. I ended taking the cover off and cleaning everything out. Took a little to clean the old gasket up, but wasn’t bad. I had a paper replacement gasket, but didn’t feel confident in it when I was putting the cover on so I used the red gasket maker. Next up is the transfer case fluid and transmission fluid and filters.
