Ambient Thermostat for outside temp
Old Apr 25, 2019 | 03:43 PM
Frank Torres's Avatar
Frank Torres
Default Ambient Thermostat for outside temp
Hey Everyone!! So my 2009 Dodge Ram SLT outside thermostat is being weird.. it will not display the temp from outside. Once in a while, the temp will pop out on the display screen but it will display a wrong temp then disappear. I want to replace the sensor.. thing is I don't know where the sensor is.
Old Apr 25, 2019 | 05:07 PM
TrueDogman's Avatar
TrueDogman
Up front beside rad. Usually LF corner I believe between rad and headlight ??
Old May 2, 2019 | 10:03 PM
Frank Torres
I replaced the sensor but still no luck... any ideas?
Old May 3, 2019 | 01:27 AM
primem's Avatar
primem
do you have a scan tool?
if yes unplug the sensor and see what it reads...it should set a circuit high code are read really cold -40*C
jumper the two pins together....it should now set a circuit low code and read a high temp
if it does all these things the wiring is ok.
the temp displayed on the dash or console is not a live reading all the time. the sensor has a set of parameters before it updates so it may not always be correct.
Old May 3, 2019 | 09:46 AM
Frank Torres
I don't have a scan tool. The temperature would display once in a while displaying a - degree than would disappear.
Old May 5, 2019 | 10:47 AM
primem's Avatar
primem
the fault can only be:
the sensor
the wiring
the module
if you can't diagnose it due to lack of tools....your options are to guess or pay someone to diagnosis it.
