Ram Door Lock Problem
Old Apr 25, 2019 | 09:19 PM
Captainron19's Avatar
Captainron19
Default Ram Door Lock Problem
Have a 2018 Ram quad cab and having a problem with driver side rear door lock
Door will not stay locked ... if I hit the lock button it immediately locks then unlocks .... when I start driving and the automatic locks engage I hear it lock and then immediately unlock. I even tried manually locking and as soon as I close the door it unlocks. Any ideas?
Old Apr 25, 2019 | 10:59 PM
SHO Rod's Avatar
SHO Rod
Is there a chance someone has left one of the key fobs in the truck? That wouldn't seem to explain the doors unlocking while driving, but it could explain the others.
Other than that you may need to get a professional grade scan tool connected to see what the central locking system thinks is wrong and causing the doors to unlock.
-Rod
Old Apr 25, 2019 | 11:01 PM
Captainron19
Nope no other Fobs in the truck and it is just the rear driver side door unlocking
Old Apr 26, 2019 | 12:15 PM
DodgeCares's Avatar
DodgeCares
Hi Captainron19,
Are you considering taking your truck to the dealer to have this addressed? If so, please send our team a private message and we would be happy to offer an additional layer of assistance to this process!
Alex
Dodge Social Care Specialist
Old Apr 26, 2019 | 01:50 PM
SHO Rod's Avatar
SHO Rod
Oh, I missed that it was only the one door. Did you happen to notice any strange sounds prior to this issue, such as a louder than usual screeching/buzzy noise, when the locks would lock or unlock?
With it being a 2018 do you still have factory warranty remaining?
-Rod
Old Apr 26, 2019 | 01:56 PM
Captainron19
The only noticeable sound is when locking the doors and that one door makes a double locking sound (almost like a vibrating) so when I click on lock (either on door or with fob) it locks then immediately unlocks. Like I said it even happens when I manually lock door then close it (unlocks right away) . The only way to lock it is to close the door first then push down the lock manually .
I bought it used hut but I have the remainder of the factory warranty so made an appointment to take it to dodge next week
