park assist
Old Aug 11, 2019 | 10:37 AM
ljanssen's Avatar
ljanssen
Default park assist
I have a 2010 1500 Sport. My park assist is off and I can not turn on with switch on dash. I go to set-up on EVIC and I can not switch it sound or sound with warning. I have replaced harness and all four sensors on rear bumper. Anything else I should be looking at?
Old Aug 12, 2019 | 02:36 PM
SHO Rod's Avatar
SHO Rod
Do you see the options in the EVIC you're just unable to select them, or does the option not even appear in the EVIC? Has it ever worked since you owned the truck? Do you have access to a professional grade scan tool that can access the park assist system?
-Rod
Old Aug 13, 2019 | 06:37 AM
ljanssen's Avatar
ljanssen
option appears in EVIC but I am unable to change from off position, It has been in alarm since truck purchased, I have replaced all four sensors and wiring harness at bumper. I don't have a scan tool that will
access the park assist.
