Help- bolt backing out front driveline
Old Aug 31, 2019 | 09:38 PM
cfraser's Avatar
cfraser
Default Help- bolt backing out front driveline
So I was under my 2010 3500 Mega cab looking for some mysterious rattles. While checking things I noticed that the front driveline at the transfer case had one of the bolts backed out about a 1/2 inch. What the heck?
1. How did that happen? 2. Can I get it back in while the truck is on it’s wheels, etc.
Thanks!
Old Aug 31, 2019 | 10:30 PM
Nicholas Seyfarth's Avatar
Nicholas Seyfarth
I wouldn't see why not, however you may have a bad u joint that caused the bolt to back out, or if not it may be bad now. I would replace the u joint and put some blue loc-tite on the threads of the bolt or bolts to prevent them from backing out. Check for torque specs.
