Throttle body tc
Old Oct 9, 2019 | 09:04 AM
NMSOG's Avatar
NMSOG
Angry Throttle body tc
2012 RAM 1500 2WD 4.7L
Replaced throttle body w/ napa rebuild,popped same 2122?trouble code after ~40mi
cleared code and drove w/ no issues popped same code when cranked this morning.
Any ideas?
Old Oct 9, 2019 | 09:19 AM
Some recommended troubleshooting and repair steps are:
Carefully check the throttle position sensor (TPS), wiring connector, and wiring for breaks, etc. Repair or replace as necessary
Check the voltage at the TPS (refer to a service manual for your vehicle for specific information). If the voltage is too low that is indicative of a problem. Replace if necessary.
If recently replaced the TPS may need to be adjusted. On some vehicles the installation instructions call for the TPS to be properly aligned or adjusted, consult a repair manual for specifics.
If there are no symptoms at all, the problem may be intermittent and clearing the code may resolve the issue temporarily. If this is the case then you should definitely check the wiring to be sure it's not rubbing on anything, grounding, etc. The code may come back.
Old Oct 9, 2019 | 10:24 AM
NMSOG's Avatar
NMSOG
Thumbs up
Thanks
i will give it a shot...
No performance issues with truck, just code
everything looked clear and for the most part clean for one with 151k on it
new to dodges(company truck)
thought this might be a re-occurring or "built in" problem
