2011 RAM 1500 differential fluid
Hi All,
The differential on my 2011 RAM 1500 5.7L, 4x4 (build date is 2-11) has started to leak. I don’t have the $$ to have it repaired right now so want to add fluid as needed to get by (I know I should fix the leak, but just can not at this point).
Ive read a number of posts about the fill hole (rubber vs threaded) but I couldn’t come to a clear understanding. My differential has a threaded fill hole and a threaded drain hole. From what I have read, I need to fill it to 5/8” below the threaded fill hole. Is that correct?
thanks for the help
thanks for the help
not sure which axle you have...their are 4 options. service info I have says to fill to bottom of fill hole.
most that are filled below the fill hole have a fill line and instructions etched into the diff cover.
if you are leaking from the diff cover you can leave it....if you are leaking from the axle seals...its a safety issue and needs to be repaired before the rear brake linings get contaminated.
That would be the pinion seal that's leaking. I appreciate you wanting to keep the fluid topped off until you have the means to fix it properly, but from the images above, you've probably only lost less than a teaspoon worth of gear oil. I don't see any droplet forming. From what I can seem in the image, if it were my vehicle, I'd check the axle seals (remove the brake drums/rotors) and if they are not also leaking, I'd keep an eye on the pinion seal area for signs of significantly more leaking, and until then, put the cost of the bottle of gear oil towards the pinion seal repair funds.
-Rod
-Rod
